voltage too high???
Old Aug 13, 2012 | 11:24 PM
sportcoupe-z28's Avatar
Car: 82 Camaro SC
voltage too high???
i just noticed yesterday that the voltage gauge on my car is reading at about 16-17. this scared me. what could it be? is it safe to drive? its almost into the orange on the gauge.
Old Aug 13, 2012 | 11:51 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: voltage too high???
could be a bad voltage regulator in the alternator or a problem with the
wiring to the alternator.When the brushes wore down in my alternator,
the voltage started spiking up to 16-17v but did not stay steady up that
high.Besides burning out light bulbs,voltage that high will boil the battery
dry and ruin it-fix ASAP
Old Aug 14, 2012 | 02:03 AM
Cat Amanigh's Avatar
Car: 91 RS
Engine: 305 topped w/ Summit Holley Clone
Transmission: 700R4, a placeholder for that T-56
Axle/Gears: 7 5/8, 2.73
That orange is there for a reason. It means "don't drive unless your life depends on it!"
Odds are highly in favor of it being the alternator. Lucky for you it's a really easy fix, and well under $100. You can even pick up a shiny new chrome single wire from Summit for < $100.
Old Aug 14, 2012 | 08:23 AM
Car: 82 Camaro SC
ok so im guessing its the alternater itself then. i checked all the wiring and it was all good...
Old Aug 14, 2012 | 08:36 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Alternator.
Old Aug 14, 2012 | 08:46 AM
Car: 82 Camaro SC
fack, i was gonna pull the engine next week, think it will be alright til then? i have a alternator on the engine thats going into it. im guessing and alternator is and alternator and it doesnt matter about engine size? going from a 2.8 to a 355
Old Aug 14, 2012 | 11:08 AM
Car: 91 RS
Put the other alternator on. It's like 4 fasteners to put an alternator on, and you could cook your electronics and your battery if you don't do it. There's a regulator for a reason. Remember, orange zone on the gauge means "don't drive unless your life depends on it."
Old Aug 14, 2012 | 10:07 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Disconnect the battery before you start swapping the alternator.
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
sammy52401
Nov 11, 2015 07:20 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
92projectcamaro
Sep 29, 2015 07:07 PM
