Fuel Pump Harness Wiring
Old Aug 15, 2012 | 03:45 PM
olskoolclassics's Avatar
1989 Camaro 350 TPI engine going in a 1936 Plymouth is the project. All is wired except for a few things. Trying to figure out the fuel pump harness. There are 3 wires that come out of the fuel pump harness. Gray, Black & Purple. The gray is for the fuel pump motor. What are the black and purple wires for. Would like to know which one is for the sending unit and what is the other wire for. Found the wire schematic on Austinthirdgen but his diagram says the sending unit uses a pink wire.
Old Aug 15, 2012 | 05:20 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Fuel Pump Harness Wiring
Purple is for the sending unit (0-90 ohm).
Black is ground.
Chevy used pink or purple wire, whatever they found on the shelf. Please don't be surprised by that.
Btw, we are guys, we can just say: "purple is darker pink, right?"
Old Aug 17, 2012 | 11:42 PM
13reedtd's Avatar
do you guys know any thing about fuel pump mines not turnig on i have tried every thing pls help
Old Aug 18, 2012 | 09:51 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
What car , what engine?
When doesn't it "turn on" ?
What tests have you done?
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
9192camaro
16
Feb 3, 2019 12:21 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
