Crank No Start
Old Aug 19, 2012 | 09:38 PM
KidwithIROC's Avatar
Car: 1989 Iroc-Z
Engine: 5.7 350 TPI
Axle/Gears: 2.77
Crank No Start
1989 Iroc has 40lbs Fuel pressure, Spark, good injector pulse, will take twenty cranks or so to start after it has sat for more than 6 hrs. everything seems to check out. Any ideas?
Old Aug 20, 2012 | 07:12 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Crank No Start
Originally Posted by KidwithIROC
will take twenty cranks or so to start after it has sat for more than 6 hrs. Any ideas?
When it happens again pull a spark plug before it fires up .
Wet plug ; no ( or weak ) spark
Dry plug ; no fuel
At least gives you a direction to investigate
Old Aug 20, 2012 | 10:56 AM
crazyjc15's Avatar
Car: 1987 GTA.
Engine: 5.7L TPI
Re: Crank No Start
trun the key foward and let the fuel pump prime, then turn the key off and wait 10 sec. turn the key foward and let the pump prime again. repeat this 2-3 times then try to start the car, if it fires right up then you looking at a fuel presure check valve. unfortuneatly its usualy built into the pump and if it were me, id wait for the pump to fail before changing it.
Old Aug 20, 2012 | 04:50 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Crank No Start
When did you measure the fuel pressure? While cranking when it won't start?
Do you hear the fuel pump prime when you turn the ignition on?
If you spray fuel (carb cleaner or similar) into the intake prior to starting after 6 hours, will she start?
Caspar
Jun 19, 2016 11:19 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
Tonyy_z
Aug 12, 2015 07:20 AM
