Interior lights power mirrors not working. Fuse maybe?
Old Aug 22, 2012 | 08:56 PM
Irishfighter's Avatar
Car: 1989 Cheverolet Camaro Iroc-Z
Engine: 5.7l 350 V8
So I have an 89 Camaro I recently tried to install a new dome light which is an LED one. The person I bought it from a couple weeks ago didnt have the headliner installed and there is no cover for the light so it fell out. When I tried to put it back in I think something shorted because the power mirrors cigarette lighter and all interior lighting stopped working. I read some posts saying it could be the ACC fuse which my fuse box lacks having one in it but how would that fix anything if there was never a fuse in it to begin with?
Old Aug 22, 2012 | 09:52 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: Interior lights power mirrors not working. Fuse maybe?
Check your fuses, you should need an acc fuse. https://www.thirdgen.org/forums/elec...-accurate.html
Old Aug 23, 2012 | 02:35 AM
MerethriX's Avatar
Car: Pontiac Trans Am GTA
Transmission: th700
I have those same problems. But when I tried to put new ACC fuse it burns with sparks right away. I think the problems is in groundings somewhere around the car.
Old Aug 23, 2012 | 08:01 AM
red rock's Avatar
Car: 1987 iroc
Some times the biggest problem is the cigar lighter, it grounds out on the housing and blows fuses.
Old Aug 23, 2012 | 08:02 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Merethri, I would look in the cigarette lighter first. It is historically and statistically the #1 reason for the ACC fuse blowing. Often people find paper-clips or coins in the cigarette lighter which cause a short in the circuit.
If that is not your problem, you can check all the devices on the ACC circuit (diagram here) and try to find the one that is causing your short.
Hope this helps.
Lou
BRoss99
Aug 10, 2025 05:08 PM
jaridjohn
Jul 8, 2024 03:49 PM
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Feb 4, 2016 07:10 AM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
