91 RS TBI won't start, VATS?
Old Aug 26, 2012 | 05:26 PM
Zavira's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
So, I've tried searching all over for someone with similar issues, but nothing. I Just bought this car a week ago, and I got it in a non running state. It wasn't getting any fuel to the TBI, so I tested and replaced the pump and filter, but it still wasn't pressurized. I jumped the pump relay to give the pump constant power, and it pressurized the system, but the injectors do not fire to start the engine. Here's where it gets weird, as the car will start on starting fluid, and only then will the injectors do anything, but all they do is spray super slowly. They spray once, which barely keeps the car alive, but by the time they spray again, the car is dead. But like I said they don't spray at all if I am just trying to crank the car. Now, the security light is constantly on in the car, even when cranking, which, if I understand correctly, means it's the VATS, but I thought you couldn't even crank the car when the VATS is messed up. Any help would be much appreciated. Thanks.
Old Aug 27, 2012 | 08:46 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 91 RS TBI won't start, VATS?
Nothing to say a PO hasn't bypassed the starter parts of VATS
https://www.thirdgen.org/vats_passkey_system
Glowsock
Jul 24, 2025 03:15 PM
Jae992
Aug 27, 2015 09:07 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
