wiring nightmare
Old Aug 28, 2012 | 07:57 PM
jdawg1276's Avatar
Car: 1988 camaro
wiring nightmare
Well long story short I have a 86 z28 iroc was a 305 fuel injected and then some back yard know nothing put in a 350 with Carb and left about a thousand wires that don't hook up to anything. Slot are hot all the time and the electric fan was super rigid a hot wire used a red 18 gauge wire as the negative wire so I ripped that out now to my questions how can I fix it plus remove all the wires laying around and wire my two aftermarket guages right or do I need a professional to do it if so is a Chevy dealership the best and is it going to cost more then the car is worth? Any replay will help love the car but am growing tired thanks
Old Aug 29, 2012 | 11:35 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: wiring nightmare
Originally Posted by jdawg1276
some back yard know nothing...
No offence, but it sounds like you are continuing in the same vein as your po...
He may have actually done you a favour, leaving the factory wiring intact instead of hacking it off randomly as most guys seem to be so madly intent on doing. You can then easily restore factory functionality in future if you choose; just tuck anything unused out of the way for now. Remove the ecm harness entirely and store it away.
As for the fan(s) control, it does have to be 're-engineered' now that the ecm is not doing it. An aftermarket fan controller of some type would be best, temp switch next best, or toggle switch if you don't mind the inconvenience. Or at least wire straight to the ign thru a fuse if you are really lazy Try searching for details on any of these, scores of threads to be found.
Old Aug 29, 2012 | 11:38 AM
jdawg1276's Avatar
Car: 1988 camaro
Yeah but all the hot wires what do i do with them
Old Aug 29, 2012 | 11:43 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Ok trying to get a feel for what you are dealing with - pics would help. There are a lot of cut wires? - ie it IS a hack job?
Old Aug 29, 2012 | 03:53 PM
Mishimoto's Avatar
Don't take it to a dealership unless you want to spend 3-5 times what you paid for the car. I agree with TreeFiddy, pics would help a lot.
Jorlain
Aug 24, 2022 05:11 PM
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
