Where is the "power junction block" on '88 5.7 T/A?
Old Aug 29, 2012 | 02:40 PM
G8T8A's Avatar
Car: '88 GTA
Engine: 5.7L
Transmission: 700R-4
I've been told to check the power junction block "near the battery" to see if it the cause for my low voltage (corrosion on a terminal/plug), but I cannot find anything that looks like what I expect to find. Where is it on a '88 5.7 T/A?
I do not see any orange wires all going to one spot. (read a lot of threads I searched yesterday and thought I should look for oranges wires...)
Years ago I stripped the Star/Torx head bolt that holds the battery NEG cable to the PS bracket. I was in a hurry and left the NEG cable in place. Since I was converting to a top post battery, I added an extension to the end of the stock negative cable. Later on when I added the "Big Three" mod, that came in handy for mounting those added grounds at the battery.
I have a similar extension on the POS cable. My current issue of low voltage was present before I made these changes, so I do not think they are a source of the problem. And when I did the Big Three mod, it didn't help it either. (battery sees 14.x all the time regardless of low load or every accessory running, but accessories run slow and the dash gauge reads 2-5 V lower than the voltage at the battery)
When looking for orange wires to lead me to a junction block, I see where the POS cable has three wires piggybacked on: 1. a large gauge wire run to the ALT output (added with the Big Three mod), 2. a wire that is orange that goes to some kind of inline weather-pack plug, and 3. a black wire that runs to a second inline weather-pack plug and the other end of the plug has a red wire.
Are those three wires what would run to a junction block if I had one?
I have two pics attached with some labeling.
Attached Thumbnails Where is the "power junction block" on '88 5.7 T/A?-pos-cable-wires-rs.jpg   Where is the "power junction block" on '88 5.7 T/A?-wires-rs.jpg
Old Aug 31, 2012 | 03:39 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Where is the "power junction block" on '88 5.7 T/A?
Middle pic is a cr*ppy pic of what the terminal block looks like
https://www.thirdgen.org/forums/post...724-post1.html
Old Aug 31, 2012 | 03:54 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Some power feeds are direct from the Batt with their own inline fuses or fusible links
From a 91 but you get the idea
Old Sep 1, 2012 | 02:11 PM
G8T8A's Avatar
Car: '88 GTA
Engine: 5.7L
Thank you for the posts.
Frozer!!!
Jan 19, 2024 04:55 PM
stalkier
Dec 6, 2015 11:25 PM
z28addict8490
Sep 5, 2015 03:56 PM
pimprs
Aug 24, 2015 11:20 PM
sailtexas186548
Aug 24, 2015 10:11 PM
