charging system
Old Sep 18, 2012 | 04:02 AM
snarley's Avatar
Car: 1987 z28 camaro
Engine: 305cid lb9
Axle/Gears: Base Z28 drum 3:23 ]
charging system
alright. so tonight i got a deck wired in. worked fine. but on my drive home the voltage flatlined. i had maybe 7-8 volts being read on the gauge. i believe something is sapping the alternators charge somewhere. iv unplugged everything we added in today. i however have the fans connected to the batt positive, to a 30 amp switch, then grounded. the fan system was ran through 14 gauge wire and hooked up onto a switch under the dash. i changed it out with 10ga wire and a bigger switch. where should i start with this issue. i had the same issue when i tried to wire in the fog lights. im just worried that somewhere in the harness is a massive clusterf%*k of a mess. alt seems to be fine but ill check tomorrow morning for sure. its relitivley new
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
J.C. Denton
Sep 21, 2015 04:23 PM
sahlomonic
Sep 20, 2015 07:15 PM
Slush92RS
Sep 2, 2015 08:56 PM
