New Hatch Question
Old Sep 23, 2012 | 12:52 PM
86_irocz-28's Avatar
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
New Hatch Question
So since my iroc will no longer be an automatic for 1(no safety release wiring needed) for two i will be using the release switch in the 96 dash, 3 i dont mind not having the electric pull down so here comes the ? what wires release the hatch there should be a ground a positive to the switch and positive from the switch to the battery correct? heres two pics for reference
Old Sep 23, 2012 | 06:00 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: New Hatch Question
Just the black one that looks like it has a splice in it that connects to the bullet shaped thing pointed towards the driver's side wheel... The solenoid grounds through itself to that black wire on the one bolt holding it to the motor assembly.
Old Sep 23, 2012 | 06:16 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
I have a question also. My motor stopped working and i was wondering if there is a fuse for it? If not is there a way that sense the pull down does not suck the hatch all the way down, is there a way to get it all the way down in place???? It does shut and latch but i dont like the gap. Just until i get it fixed right.
Old Sep 23, 2012 | 06:18 PM
Engine: 2.7L V6
Axle/Gears: 4.41
The 3 mounting bolts seen in the pic have adjustment holes...
The fuse is the LID fuse in the fuse panel. May or may not be part of the panel itself, it may be a separate fuse in a holder attached to the main panel. It's a green fuse.
Old Sep 23, 2012 | 06:31 PM
Engine: MPFI
Thanks Maverick
Old Sep 23, 2012 | 10:51 PM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
So using that ground and running the other black wire to the switch and a positive out of th switch to the battery would work?
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
Vintageracer
Jan 10, 2020 05:33 PM
madsv1000
Aug 20, 2015 06:45 AM
redmaroz
Aug 16, 2015 11:40 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
