GPS speedometer sending unit
Old Sep 25, 2012 | 10:31 AM
fishyz's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Does anyone know if this GPS speedo sender will work on a 91 speedo?
http://www.intellitronix.com/gps-sender.html
Old Oct 19, 2012 | 09:37 AM
rudolphschenker's Avatar
Car: 1990 IROC Z, 1987 IROC Z, 1986 Fir
Re: GPS speedometer sending unit
I use a GPS speedo in my 69 Fastback, works great. You need to find out what the signal is that your speedo uses. It appears that this unit will work with all the common signals. However your speedo needs to be a programmable. After market programmable speedos are available.
Old Oct 19, 2012 | 01:24 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Our electronic VSS normally generates a 4000 pulses-per-mile signal. The speedometer-buffer-box (on TBI) or the ECM (on TPI) splits that signal to go to cruise control and the speedometer in the instrument cluster and at the same time it scales it down to 2000 pulses-per-mile.
So that specific GPS sender will work with your car if you plug it into the yellow and purple wires instead of the VSS.
PurelyPMD
May 5, 2016 04:57 PM
R13_Braz
Sep 18, 2015 05:00 PM
Springster
Sep 13, 2015 01:38 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
Glowsock
Sep 5, 2015 07:48 PM
