Hi all.
Now that i have the right oil pressure sender , how do you get it installed past the distributor?
Should it have an adapter so its at 90 degrees or something?
Cheers.
Cheers.
Factory used several different ways of getting clearance
L98 Vette sender shown
My L98's is right above the oil filter:
Mine is def up near the distributor. But does anyone know the type of adapter, size, thread etc, that the engine block takes?
Ebsy is looking my best bet because the stores here in Oz don't seem to keep any.
Quote:
If you are using the hole under dist then thread is 1/8" NPTOriginally Posted by djjon76
Mine is def up near the distributor. But does anyone know the type of adapter, size, thread etc, that the engine block takes? Any parts shop should have a range of brass fitting in 1`/8" NPT
http://www.ebay.com.au/itm/BRASS-FIT...item3cc72047f2
http://www.ebay.com.au/itm/BRASS-OIL...item19c16501b5
Perfect. That's exactly what i needed to know:-)
Cheers.
Cheers.
