repinning gauges cluster help?
Old Oct 6, 2012 | 06:30 PM
flyin's Avatar
Car: 84 trans am
Engine: 355
Transmission: 700r
Im in the process of changing my 84 trans am to a 86 trans am gauge cluster to get the 140 speedo and i know the pins need to be switched around in the connectors for this but im having problems getting the pins out of the connectors? so what is the trick? ha
Old Oct 7, 2012 | 05:44 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Re: repinning gauges cluster help?
I don't know about those specific connectors, but usually you slip a thin narrow blade on one side of the contact to push down a tang that locked when the wire was pushed into the connector. Depending upon the connector I've had luck using a tiny jewelers screwdriver.
Check this out:
http://www.dsmtuners.com/forums/arti...onnectors.html
Old Oct 7, 2012 | 01:17 PM
flyin's Avatar
Car: 84 trans am
Engine: 355
Transmission: 700r
thanks for the reply but im still not getting it :/
Old Oct 7, 2012 | 01:46 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
You looked at the link I provided, right? You could try cutting a plastic soda straw and making a tool that will slide in between the contact and the plastic shell. The wire always comes out the way it went in and you insert the tool from the mating end of the connector. You usually have to fiddle around with it pushing and then pulling on the wire while pushing the tool in from the other way. You'll have to figure out which of the four edges has the tang. Hopefully there won't be two tangs across from each other.
RS Reaper
Oct 17, 2018 07:52 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
