85 Berly dummy cluster swap 85 camaro guage cluster do I need to repin the harness.
Old Oct 6, 2012 | 08:15 PM
Fordvette's Avatar
Car: 1985 Camaro Sport coupe project
Engine: 2.8 mild cam
Transmission: T$ V6 5speed manual 4.04 first
Axle/Gears: 3.42 Limited Slip
As the title says, I have swapped out the Dummy lights cluster for a tach and intrusment .. but when I turn on the headlight dimmer the tack, oil and battery go dead. Ive been trying for almost a day to trace a bad ground and no luck. Swapped out steering column cause I added a Tilt, Swapped out the cluster, just to be safe it wasnt the printed circut board, Head light switch.. etc etc..
I was under the assumption this was a direct swap and play.. untill I looked closer in my Tech manual. The pin out are slightly different for a cluster and dummy ..
Ive searched third gen and google to no avail, either I am alone, or this is a wierd problem
See attached for the difference in pin outs Ive found, the top one, is a Camaro listing in my book, the bottom is a berly. ??
Pin 1 is different and pin 6
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
tnrednneck
Aug 13, 2015 08:57 AM
ChevyZ71
Aug 13, 2015 07:30 AM
87350gtanj
Aug 8, 2015 10:32 AM
