1991 Camaro RS No Lights at ALL!!
Old Oct 10, 2012 | 02:56 AM
Electro Panda's Avatar
Car: 1989 Pontiac Firebird Formula
Engine: 327 sbc
Transmission: 400 turbo with Shift Kit
Ok. Got a 91 camaro rs and my headlights, tail lights and dash lights do not turn on. I have checked fuses and Nothing at all. Should or could I wire it up with a switch? Just can't find the problem!
Old Oct 10, 2012 | 07:52 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Re: 1991 Camaro RS No Lights at ALL!!
I think you're going to be looking for a burned fusable link.
Old Oct 10, 2012 | 09:57 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
True, it could be fusible link A.
To find out whether it is the culprit or whether it is the switch itself, you can very easily check the following:
- horn
- dome light
- cigarette lighter
- power mirrors
- hatch release
If any of these work, your fusible link should be fine and I would be looking into the headlight switch in the dash.
Let us know what you find.
Lou
Old Oct 10, 2012 | 06:24 PM
Engine: 327 sbc
I will check them tomorrow by cutting out the fuses and connecting them and post my progress (: Thanks guys
Old Oct 12, 2012 | 11:55 PM
Engine: 327 sbc
*Update* The fuse link that goes to the starter was the issue. There are three ring terminals that are positive. Replace the fuse that has two wires going into the fuse link and wah-la. It's an Easy fix that doesn't take all day and if it did you will have lights at the end of the day. Thanks guys
Old Oct 13, 2012 | 10:56 AM
BigBadLou's Avatar
Engine: TPI
Thanks for the follow up and good job on fixing it.
And btw, it is spelled "voila" and the V is pronounced.
Old Aug 8, 2014 | 02:27 PM
71-iroc-rs's Avatar
have same issue, but by passed links nothing, have side and dash but no headlights. help c_geske@earthlink.net best thx
TheJoeY88
Dec 31, 2016 07:30 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Omega
Aug 10, 2015 12:46 PM
