85 Z28 With surge problem
Old Oct 13, 2012 | 09:39 AM
TuckettIII's Avatar
Car: 1985 Z28
Engine: 305 4bbl
Transmission: 5 speed
Hey everyone!
I have a question for you today regarding My 1985 Camaro Z28. While cruizing with the engine near 1000 rpm (+- 200 rpm roughly) the engine will begin to violently surge. this will continue until out of the above range, or engine load is increased.
During idle, the engine will not idle in this range. when idling up, it will approach 1000 rpm and immediatly jump to 1500. the opposite occures when idling down.
I am suspecting a distributor problem, but im not sure. anyone have a clue?
Old Oct 13, 2012 | 09:41 AM
TuckettIII's Avatar
Car: 1985 Z28
Engine: 305 4bbl
Re: 85 Z28 With surge problem
oops, forgot to mention. Engine is a G code 5.0 with an electronic feedback carburetor.
Old Oct 13, 2012 | 02:16 PM
hitman0187's Avatar
Car: 87 Iroc 5.7 /86 Trans am
Engine: 5.7 TPI / 350 carb
while driving its possible to be on the shift point where it will up and down shift back and forth although its difficult to do. you may want to check the ignition coil may be getting weak.
Old Oct 13, 2012 | 09:58 PM
TuckettIII's Avatar
Car: 1985 Z28
Engine: 305 4bbl
I will check the ignition coil. good suggestion. it does appear to be original. my fault again though, i forgot to mention it is a manual transmission. and i guess while im at it, a 7 pin ignition module electronic advance HEI distributor. distributor and internals are all oem spec. only addition is an MSD 6 unit, but this problem was present before the MSD was installed.
sorry everyone. been very distracted today. i think i hit all the important information though. lol
Old Oct 18, 2012 | 08:43 AM
TuckettIII's Avatar
Car: 1985 Z28
Engine: 305 4bbl
so, ive been doing some electrical work the last couple days and have had the battery disconnected. i re connected it this morning and took it out for a drive and.... my surge is GONE!! runs and accellerates smoothly all through the rpm range. WTF!?!
Old Oct 23, 2012 | 11:44 AM
hitman0187's Avatar
hopefully it doesnt return. One of the downsides of this type of fix is you were not able to identify which fix was the one that made the difference. Anyway enjoy it.... when a car is 25+ years old a new challenge is always around the corner.
bamaboy0323
Sep 3, 2015 06:07 AM
neekolzun
Aug 24, 2015 04:59 PM
jbd1969
Aug 17, 2015 07:06 PM
