behind dash wiring
Old Oct 14, 2012 | 07:50 PM
crazybird's Avatar
Car: 1987 firebird
behind dash wiring
I need to get to the group of wires underneath my windshield behind the dash. i believe the door windows and lock wires are part of this loom. any ideas?
Old Oct 15, 2012 | 01:07 PM
hitman0187's Avatar
Car: 87 Iroc 5.7 /86 Trans am
Engine: 5.7 TPI / 350 carb
Re: behind dash wiring
I think your best option may be to start taking the dashboard apart, may be the only way to have a clear view.
Old Oct 15, 2012 | 01:47 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Pop out the plastic "hush panel" that has foam on the backside. This is the thing with the fuse box lid in it. Then take out the 5 10mm screws that hold the knee bolster to the bottom of the dash and remove it. Things should be immensely more available and visible.
Old Oct 15, 2012 | 02:09 PM
crazybird's Avatar
Car: 1987 firebird
dash is taken apart, hush panels and console are out. these wires run along the defrost vents.
Old Oct 16, 2012 | 11:06 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Since the center console is out,....... remove all the 7mm screws remaining along the firewall edge of the dash housing. Then removed the screw at the botom Left and right. Next remove the 2 nuts at the top Left and Right. Finally, loosen the 13mm nuts that hold the steering column in place to thier lowest point on the mounting studs. ( Drop the column; but don't let it "hang".)
Now you should be able to pull the dash housing from the firewall and see behind it and gives you access to the firewall wiring harness shield. You're right, This is how the power window/door lock/mirror wiring gets from one side to the other. The Rear Speaker harness is also run inside the right 1/2 of this shield on many cars.
Jorlain
Aug 24, 2022 05:11 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
stalkier
Dec 6, 2015 11:25 PM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
