high beam dipper switch
Old Oct 17, 2012 | 05:08 AM
ozigreg's Avatar
Car: 92 camaro
Engine: 5 Lt.
Transmission: 4 auto
Axle/Gears: standard
i have a right hand drive 92 z28 and need to know if the dip switch was on the floor or on the stearing column or dash on the normal left hand drive car. this car was converted way back in 95 and i am now the new owner, thanks
Old Oct 17, 2012 | 09:06 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: high beam dipper switch
Oh sweet, a right-hand steering wheel. I have never seen one of those.
The hi/lo beam switch is on the steering column. On its side, by the ignition switch (which is on top). Both switches are pretty far down the steering column.
Enjoy the digging!
Lou
Old Oct 17, 2012 | 10:08 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Depends how well the conversion was done I guess. Mine was lacking the dimmer switch, even though a nice little alcove had been built for it in the bottom of the hvac airbox. Actually the airbox (in stock position) has a nice little 'U' carved out of it where the column passes though, and the U is completely paneled in with plastic, no air leaks. It's really a bit of a labour of love on the convertor's part
Instead, there was the Flintstones switch on the floor, and the column rod for the real switch just rattling there, unattached. I fixed it all up proper for column stalk switching several years back.
Has your airbox been switched r to l (full mirror conversion)? If not and it's like mine (TA in my case), you'll have to remove the instrument panel. Then drop the column down from the dash, to access the dimmer and ign switch position on top of the column.
Old Oct 17, 2012 | 03:21 PM
ozigreg's Avatar
Car: 92 camaro
Engine: 5 Lt.
thanks for this info, i shall start fixing.cheers
GTAman
Mar 15, 2019 11:40 AM
Slush92RS
Sep 2, 2015 08:56 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
