Power Antenna Problem on 87 GTA
Old Oct 20, 2012 | 10:22 PM
Steveh4263's Avatar
Car: 1987 Pontiac Trans AM GTA
Engine: 5.7 LTR
Transmission: Automatic
I'm having a problem with my power antenna on my 87 GTA. The mast was going up and down with no problem. Antenna was brand new when I had it replaced and was working fine until today. It's been a least 4 years ago since I had it replaced. But it has never been a problem until now. Now the antenna won't go up or down. The antenna doesn't continually go up or down. It has me stumped.
Old Oct 20, 2012 | 11:12 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Axle/Gears: G92
Re: Power Antenna Problem on 87 GTA
https://www.thirdgen.org/forums/hist...ld-thread.html
Old Oct 23, 2012 | 07:10 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
The relay for the antenna is behind the black panel just under the map pocket. It has 6 wires: black,white,grey,green,red,orange. Orange should be 12V at all times, key on or not. Red should be 12V only when the radio is on. If both of those check out, you probably need a new relay.
89GTAOz
May 16, 2020 09:31 AM
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
gta power
Aug 13, 2015 06:15 AM
