need help with wiring!
Old Oct 26, 2012 | 04:43 PM
Kurtis32's Avatar
Car: 86 camaro coupe
ok i have an 86 camaro, my blinkers dont work and my reverse lights dont work either, i can turn on my hazards but only the front driver light will come on. i've looked at the fuses but i dont know the codes, can anyone tell me or show me wat the codes r??
Old Oct 29, 2012 | 04:32 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Secret Code
You didn’t say if you just bot the car but that’s what it sounds like.
Test all the bulbs that don’t illuminate, and make sure they are the correct type, and installed correctly.
A common mistake is people installing dual-filament bulbs 180° rotated.
Some crazy symptoms have been reported doing that.
After doing the above, and your Hazards still don’t work, you have a wiring problem occurring after the
dark blue wire at the steering column connector.
Use a voltmeter or test light
(the type for testing for voltage, not a continuity tester) trace to find where the power stops, and most likely the break will be under-hood.
The Backup Lights are a different circuit there we will address that after you fix the previous, or someone will chime in for those.
Happy Racing!
Make Noise, Turn Left, Repeat
Old Oct 30, 2012 | 08:34 PM
talover111's Avatar
Car: 1985 & 1988 trans am
Engine: 350 tpi ; 355
Transmission: 700r4 auto; converting to 6 speed
Axle/Gears: 9 bolt 3:27 posi; 2.73 open
Re: need help with wiring!
kurtis please be alil more specific when u say codes? do you mean which fuse does which or?
Old Oct 31, 2012 | 12:20 PM
Kurtis32's Avatar
yea the fuses, sorry im not good with this stuff
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
