electrical short?
Old Nov 2, 2012 | 12:10 PM
Dabesiv's Avatar
Car: 1982 Camaro Berlinetta
Engine: GM crate motor Goodwrench 5.7 350
electrical short?
So while I was driving to work I noticed my right signal indicator bulb was dimly on constantly, as well as my battery gauge showing no charge at all. If I used the right turn signal the signal would work faster than normal and with each time the light goes on the battery gauge went even lower and the tach dropped roughly 2000 rpms and kiked back up to where it was. Any ideas?
Old Nov 5, 2012 | 04:59 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
The Ground Runaround
Your problem is consistent with an open ground.
Check the two connectors that go to the back of the dash.
Then you can check the grounds located at the ‘Convenience Center’ bracket.
The Convenience Center is located behind the knee bolster.
The Convenience Center contains a flasher among other parts
(just to help you identify it).
Happy Racing!
If You’re Passed By Your Own Tire On The Track, It’s Time For A Pit Stop
Old Nov 9, 2012 | 01:25 PM
Dabesiv's Avatar
Re: The Ground Runaround
Happy Racing!
thanks for the advice, the 2 front bolts holding up my steering column had somehow unscrewed and when I was putting them back in I found the main ground for the gauges was disconnected from the column. I didn't see the reply till after it was fixed but I do appreciate the response, didn't think anyone would.
FormulasOnly
Jul 23, 2018 08:47 AM
skinny z
Oct 5, 2015 06:23 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
evilstuie
Sep 24, 2015 02:31 AM
Formula8r89
Sep 22, 2015 04:24 PM
