86 iroc wiring screwed UPDATE PLEASE HELP
Old Nov 18, 2012 | 10:38 AM
Project86B4Z's Avatar
Car: 85 camaro RS RIP\ 86 IROC-Z :)
Engine: 2.8 MPI V6\ carbed LO5 5.7 v8
Transmission: 700r4 auto
Axle/Gears: 3.42\ posi 3.73
I managed to re wire my stereo correctly to the factory harness replaced a fuse think its a 20 amp accessory fuse which helped power the radio in accesory switch and the horn along with the cig lighter. But the problem now is
1 when turning on headlights engine on or off the radio loses power briefly then turns back on
2 i still have a no htr blower or crtsy\ dome lights and bulbs are good
3 as far as the fog lights i found the relay but its corroded but the bulbs are good
In addition i now have 2 spliced wires hanging under the heater unit one light gray and one brown and neither have stripes
Old Nov 26, 2012 | 04:24 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Radio-Active
Disconnect the brown wire, if there is one, going to the radio, then see if the headlight switch still causes the radio to loose power.
Any change?
Happy Racing!
I Didn’t Jump The Start, The Flagman Was Late
1992 Trans Am
May 10, 2023 07:19 PM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
TheJoeY88
Aug 13, 2015 06:51 PM
mustangman65_79
Aug 11, 2015 03:17 PM
blacksunshine'91
Aug 10, 2015 12:04 AM
