Should fuel injector plug's have 12v's on both pins?
Old Nov 28, 2012 | 03:53 PM
PurpleG20305TPI's Avatar
Car: 88 Chevy G20 Wagon Wheel Conv Van
Engine: 91 camaro z28 305 tpi 77k miles
Transmission: TH400
So im getting 12v's with the key in the on position from both the pink/black wire (normal) but im getting 12v's to the ecm wire too. just with the key in and on position.
Did i miss wire my harness during my swap?
Motor: 91 camaro 305 tpi w/harness
Van: 88 g20 w/ original fuse block and bulkhead. it HAD a 305 TBI w/ 2 injectors before.
I read that my stock fuel pump should be good to go as far as psi goes sense it usta operate the 2 injectors in the old motor. high pressure lines. Im going to do a fuel pressure test tomorrow.
Any thoughts??
Old Nov 28, 2012 | 04:08 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Should fuel injector plug's have 12v's on both pins?
You will have power in the acc and run position to the injector banks the ecm grounds the injectors to pulse them after the ecm gets drp.
Old Nov 28, 2012 | 04:24 PM
Transmission: TH400
Ok, so its normal to have 12v's in both pins. i thought that the ecm would tell it when to pulse by sending a signal to the blue and green(?) wires.
Since its a system operated by grounding through the ecm, then would the signal wire get grounded when its time to inject?
What should i look for when testing my injectors? ohms, certain voltages, crank test and voltage??
Old Nov 28, 2012 | 04:48 PM
Engine: Lb9
Transmission: M20
The pink on bank 1,3,5,7 is the positive feed
The pink/ blk on bank 2,4,6,8 is the positive
With any of the injectors hooked up you will get the power going back to the ecm through the injector coils on bank 1 its drk blue on bank 2 its drk green.
Your injectors should be tested hot but since you can't do that the should be ohming out around 16- 17 ohms but they all should be within .5 of each other. You can check injector pulse with a noid light. if your not getting pulse this could be a issue with the vats hz module you installed or no drp to the ecm.
Old Nov 28, 2012 | 05:01 PM
Transmission: TH400
ok, when im checking ohms, thats on the injectors themselves? and if theyre off, then the injectors are bad?
Old Nov 28, 2012 | 05:12 PM
Engine: Lb9
Transmission: M20
that is checking the injectors with the harness disconnected from the injectors.
Old Nov 30, 2012 | 11:18 AM
Transmission: TH400
ok, injectors are in spec. the fuel pressure on the other hand is NOT. gotta upgrade that pump. I thought a tbi pump would work, getting a newish one from the yard for 35$ if its as new as they say.
so im dropping the tank and gonna put the new pump in and hopefully with the correct pressure, she'll fire right up. then i can tweak the timing.
wish me luck
peace
Old Nov 30, 2012 | 11:55 AM
Engine: Lb9
Transmission: M20
you might want to spend more and get a acdelco ep241 instead of a used pump.
http://www.ebay.com/itm/NEW-AC-DELCO...325ad9&vxp=mtr
bryan623
Mar 22, 2021 06:43 PM
Jae992
Aug 27, 2015 09:07 AM
Brcharrelson
Aug 26, 2015 07:47 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
