Cruise control help
Old Nov 30, 2012 | 04:18 PM
a62belair's Avatar
Car: 88 Firebird, 87 Formula
Engine: 2.8, 5.0
Transmission: both 700R4
Axle/Gears: 3.42,3.45
Cruise control help
I have an 87 Formula that I have converted to non-cc. Edelbrock carb and performer manifold, Accel HEI dist. I have disconnected most of the sensors, but not cut the harness anywhere yet. All the dash gauges work still. The dist is on the original 'bat/tach' hookup. I would like to know how to get the cruise working, if possible. The vacuum hoses to the module are hooked up as far as I can tell, no leaks. Is there something in the four pin dist hookup I may need?
thanks...
Old Dec 3, 2012 | 05:23 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Cruise Nite 2
Using a voltmeter or test light (the type for testing for voltage, not a continuity tester) probe the gray wire at the Cruise Module.
When you switch the Cruise to ON, is there power there?
Then probe the
gray wire with a black stripe.
Happy Racing!
He Must Have Been Be Cheating - Because I Was And He Almost Beat Me.
Old Dec 4, 2012 | 01:10 AM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Re: Cruise Nite 2
NINA- I know you think you are helping, but your font and layout is REALLY annoying. Can you just go with regular type?
Old Dec 4, 2012 | 06:40 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Cruise control help
Did you delete the computer?
JamesC
Old Dec 5, 2012 | 02:00 AM
a62belair's Avatar
Engine: 2.8, 5.0
Did not delete the computer. Did go non-cc, though. I believe only the emissions have been disconnected.
Old Dec 5, 2012 | 02:02 AM
a62belair's Avatar
Engine: 2.8, 5.0
Nina, I will check on your questions soon. The 88 needs a fuel pump first. Thanks for your posts, all.
junior419
Apr 7, 2025 11:35 AM
wigmobile
Feb 26, 2025 02:56 PM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
scottmoyer
Sep 7, 2015 07:06 PM
