HELP! 91 camaro rs v6 will not crank
Old Dec 2, 2012 | 03:24 PM
Matty Saxon's Avatar
i bought a camaro last night, and it ran fine untill i attempted to install an aftermarket tach. the key turns but does not crank. seems like the car was stuck in gear or there is a bad connection from the ignition switch to the starter. i also have a theory the the starter relay could have gone bad but im not sure, possibly vats? i have no idea what im doing with this and could use a much help as possible thanks
Old Dec 5, 2012 | 09:23 PM
Raz's Avatar
Raz
Re: HELP! 91 camaro rs v6 will not crank
I personally had a vats problem after my ignition switch got stuck. after beating it with a hammer to get it lose my vats in the key went bad. so with that said. Measure ur resitor on the key. It should have some kind of ohm number. The key probably should read one of these numbers
VATS # (K)OHMS (Set your meter to the 20k ohm setting)
1覧覧 0.402
2覧覧 0.523
3覧覧 0.681
4覧覧-0.887
5覧覧-1.130
6覧覧-1.470
7覧覧-1.870
8覧覧-2.370
9覧覧-3.010
10覧覧3.740
11覧覧4.750
12覧覧6.040
13覧覧7.500
14覧覧9.530
15覧覧11.801
Old Dec 5, 2012 | 09:28 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Get to the starter relay, it should be behind the kick panel on the drivers side, you'll find three large wires and one small black/white, jumper a wire from ground to the black/white, if the car cranks over (it will not start), then vats is your issue, if it doesnt crank you could have a bad relay, neutral or clutch switch, or ignition switch, but that will get you started.
Falcon50
Aug 22, 2020 03:26 PM
db057
Apr 28, 2019 07:45 AM
RedIrocZZ
Sep 19, 2015 02:22 PM
383cam
Sep 9, 2015 06:01 AM
john204481
Sep 7, 2015 03:22 PM
