Starter heat soak issues!
Old Dec 5, 2012 | 11:41 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
After about a year of never having the problem, I am suddenly getting starter issues. I am getting heat soak that is really causing headaches! I have replaced the starter at least twice and still, any time the temp gets above 160 degrees, it will not turn over.
Am I just getting a run of bad starters, or is there another issue I need to look at?
Old Dec 6, 2012 | 06:00 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Starter heat soak issues!
Try a starter heat shield
http://www.summitracing.com/parts/mrg-3678/
or insulate the starter with a heat blanket.
If that doesn't work you can always go the remote solenoid way that guys use to cure SBC hot soak problems
https://www.thirdgen.org/solenoid
http://www.novaresource.org/starter.htm
http://www.chevyhiperformance.com/te...x/viewall.html
http://www.crankshaftcoalition.com/w...-_no_hot_start
Old Dec 8, 2012 | 08:27 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
i had this problem. i think the problem is the relay thats part of the vats system.anyway i wired in a ford solinold in and never had a problem since.
Old Dec 8, 2012 | 11:48 PM
1986tpiiroc's Avatar
Car: 1986 IROC-Z
Axle/Gears: Dont know yet
Had the same problem with my 86 IROC. I installed a mini-starter, forget which brand, but that cured my heatsoak problem and starter starts car everytime no matter how long ive been running the car.
Street Lethal
Apr 30, 2019 12:14 PM
Cornholio7979
Sep 20, 2018 02:31 AM
Wesly_66
Aug 26, 2015 09:55 PM
destroyerwes
Aug 26, 2015 08:17 PM
86Base
Aug 8, 2015 01:34 PM
