I need help, harness conection problem!
Old Jan 4, 2013 | 12:13 PM
Jk_Under's Avatar
Car: 91 Camaro RS, 84 2.8 5speed
Engine: 305 5.0L
Transmission: Auto, 5 speed
On my 91 RS, the harness where it goes into the firewall is messed up. A while back my wire going to my starter burnt, and then the harness has a loose conection. If im not pulling up on it (the conector on the drivers side going into the firewall) theres no power to my car except the headlights, right now i got a rod propping it up, any suggestions on what to do?
Old Jan 6, 2013 | 05:22 AM
deadtrend1's Avatar
Re: I need help, harness conection problem!
Try taking that bulkhead connector apart, and make sure its clean and theres no corrosion? I think its a 7mm or 8mm sized bolt that holds them on.
Old Jan 6, 2013 | 06:46 AM
dads old blue 9's Avatar
Car: 1990 z28
Engine: 5.0
Transmission: t-5 wc
Axle/Gears: 4th gen 3.42 posi
whar he said
midge54
Sep 2, 2020 07:13 PM
TheJoeY88
Dec 31, 2016 07:30 PM
toones
Jan 6, 2016 06:00 PM
fbirdroller
Sep 2, 2015 10:27 PM
g.l.mos
Aug 22, 2015 12:02 AM
