vats help PLEASE !!!
Old Jan 5, 2013 | 06:45 PM
cj z28's Avatar
Car: 1999 silverado 1989 iroc 1988 s10
Engine: 4.8,5.7,4.3
so I was working on my car told and disconnected 2 wires that had a twist connector on them that ive used before to splice into with no problem but then my car wouldn't start and the security light came on the original ignition is under the dash and I think its acting up what car I do to bypass it all together some 1 told me to splice a transistor in place of this original ignition but wanted to make sure and what type transistor ... or if it could be something lese wrong all together
Old Jan 5, 2013 | 06:48 PM
cj z28's Avatar
Engine: 4.8,5.7,4.3
Re: vats help PLEASE !!!
disconnected the battery and played with the original ignition alittle and then it started now im really confused ....but I don't need this happening when im out and then get stranded so still need help fixing ...any ideas ???
Old Jan 5, 2013 | 08:49 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Not a transistor the appropriate resister bypassing the key pellet and lock cylinder contacts. Read this leak I have walked through the ways to bypass or repair the passkey system.
https://www.thirdgen.org/forums/tech...-i-bypass.html
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
AmorgetRS
Sep 28, 2015 09:33 PM
86White_T/A305
Sep 21, 2015 05:28 PM
Winchester1094
Sep 15, 2015 09:48 AM
