TPI to Carb wiring mistake maybe HELP!!!!
Old Jan 12, 2013 | 12:05 PM
shwinny's Avatar
I took my whole original 1987 TPI ecu and wire harness out and swaped it for an 86 carbed harness and ecu. I didnt cut or snip any wires taking it out.
My question is will an 86 carburated harness work with my 87 to run my carburated 383 stroker with HEI msd distributor. I have the digital dash on my 87 GTA. The 86 harness looks very similar and has the same drivers side Plug. I am not sure if i pulled the trigger to quicklly and made things harder or having the carburated harness will make things easyier. I have the old engine out and have the new 383 Stroker ready to install. I havent ran the 86 wireharness yet. Its just pluged in on ther passenger side and laying on my windshield. I am hoping someone can help me out.
Old Jan 13, 2013 | 07:23 PM
kyle39's Avatar
Car: 1986 trans am
Engine: 355 sbc
Transmission: th 350
Re: TPI to Carb wiring mistake maybe HELP!!!!
if your going with a carb all you need is a power wire to your distributor tach wire should be the same as before. i had tpi and went with a carb and i reused my orignal harness
Old Jan 15, 2013 | 05:18 PM
shwinny's Avatar
does anyone know if there is a diffrence between the digital dash harnes from an analog harness. i really need to figure this out. i have a harness from an 86 carbutated car but it didnt have the plug for the digital speedo. can some one please help. its an 87 GTA with the digital dash. i should have kept my original harness. what years cars i can get away with.
Old Jan 15, 2013 | 06:12 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by shwinny
. its an 87 GTA with the digital dash. i should have kept my original harness..
Not sure why you would swap the dash harness with a carb swap.
All you usually do is disconnect the ECM and rework some wires in the engine bay
Can't you put your old harness back in?
Old Jan 15, 2013 | 06:28 PM
shwinny's Avatar
the old harness is gone. a guy said an 86 carburated wireharness will work but it wontn i have the didgital dash and the harness doesnt have the trans speedo plug.. Im not talking about the dash harness but the engine harness. I should have kept the engine harness but now i need to find another one i guess. Learn from my mistakes. i just need to know what years are interchangeable.
Old Jan 17, 2013 | 09:20 PM
shwinny's Avatar
I'm just hoping the drivers side plug from the 86 will have the same pin outs for starter/lights/oil pressure/ alt/ wipers/ tach etc. I wish someone would know or even help point me in the right direction. I have 2 harnesses
To work with. But then again my speedo will have to be aftermarket. Does anyone have an 87 or 88 Gta digital dash harness laying around.
Old Jan 17, 2013 | 09:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I wouldn't worry much about the ECM harness, only maybe 2 wires in it are even useful to you on your setup.
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
86IROC112
Aug 17, 2015 02:00 PM
stalkier
Aug 13, 2015 12:59 PM
Sanjay
Aug 12, 2015 03:41 PM
