Need wiring help please...
Old Jan 13, 2013 | 10:28 AM
ld91's Avatar
I'm putting this 89 Iroc back to original and came across some wires that had been cut. I need help figuring out what these are/where they go.
Are there plugs missing or what? Any help appreciated.
Attached Thumbnails Need wiring help please...-iroc-wiring013.jpg   Need wiring help please...-iroc-wiring-015.jpg   Need wiring help please...-iroc-wiring-017.jpg
Old Jan 13, 2013 | 11:09 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: Need wiring help please...
Looks like pink, white read and blue.
Looking at the location, the pink and white would likely be coil connections. The pink should have 12V power when the key is on and in the start positions, if it is for the coil. The white would connect to the tach, so performing a continuity test between the end of this wire and the tach pin at the cluster will verify that.
I'm not sure what the red and blue wires are for.
Old Jan 13, 2013 | 11:40 AM
ld91's Avatar
Thanks for the reply.
Near the distributer-one wire is gray and the other is red w/ black stripe.
The bigger wires located near the top is a big light red, big red, big black, small blue w/ black stripe and a white one.
The wires going to the fan/ac has also been cut. There is a big red and a big black wire in that cluster. Could these possibly lead to those?
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
