Wires disconnected under dash
Old Jan 17, 2013 | 03:51 PM
Termanalor117's Avatar
Car: 1991 Pontiac Firebird Trans Am
Engine: 1987 Chevy 355 TPI Mild Cam
Transmission: 5-Speed T-5 WC
Ok so my cruise control doesn't work, bought it like that from someone. So i went to test the switch and saw that this yellow connector thing under the steering cover thing was disconnected and the wires went to nothing. There was also a blue connector that had some flat copper prongs on it that wasn't plugged in either. The picture is of the yellow connector, my camera couldn't see the blue one but they are right next to each other. What do they go to?
The other two pictures are from under the hood both right next to the battery. The one is just all cut off and I have no idea where it goes and the other seems to be a ground for something but not sure what. The single wire is on the other side of the car and it just goes into a bunch of wires and disappears.
Everything seems to work fine, The car had fog lights at one point but got removed with a new bumper.
Attached Thumbnails Wires disconnected under dash-0117131640.jpg   Wires disconnected under dash-0520121314.jpg   Wires disconnected under dash-0520121315.jpg
Old Jan 17, 2013 | 04:53 PM
dads old blue 9's Avatar
Car: 1990 z28
Engine: 5.0
Transmission: t-5 wc
Axle/Gears: 4th gen 3.42 posi
Re: Wires disconnected under dash
the first pic is the conector for the air bag (is there an aftermarket steering wheel?) if you plug this wire back in make sure the battery is disconected first . the third wire is bolted to the body and needs to go to the battery , I assume somebody replaced the ground wirw with an after market single wire , that ground is important ! you can get a terminal end at autozone and conect the wire in the pic along with thick wire that runs to the block. the other wire I,m not sure.
Old Jan 17, 2013 | 08:15 PM
Yes it has an aftermarket steering wheel, no airbag.
And ok, thanks for the help
Ghettobird52
Jul 5, 2024 11:18 PM
Jorlain
Aug 24, 2022 05:11 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
stalkier
Dec 6, 2015 11:25 PM
stalkier
Aug 13, 2015 12:59 PM
