How to wire power locks and windows
Hello...
I always wanted to power my Windows and locks... Si i got this set of doors
From a friend... Buy i can't find the harness or some wire ... I Did a search jefe but im kinda lost... If someone have advise to how can i wire ill appreciated
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: How to wire power locks and windows
Of course you will need switches for the power windows. The only other special item is the power door lock relay. Probably the only source would be a used one - it will be located behind the driver's side kick panel, you can't miss it. Here are the diagrams for both circuits.
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
I just assumed the doors you acquired from your friend were already loaded with the window motors, door lock switches and actuators. You might even need the regulators specific to PW cars, but I'm not sure.
If you have none of these parts, there's no doubt your best course of action would be to rob the complete setup, including the harness out of a junkyard donor. Piecing this together will be both expensive and a pain in the a$$.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
