Odd headlight problem
Old Feb 11, 2013 | 09:49 PM
dairishman85's Avatar
Car: 84 Camaro
Engine: 305 5.0 4 barrel carb
I have dash lights, running lights, but no headlights. Changed all the fuses, still no headlights.
Old Feb 11, 2013 | 11:35 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: Odd headlight problem
Sounds like the headlight switch is bad or the dimmer/bright switch is bad. Power goes from the headlight switch thru the dimmer switch then to the lights. Either one of those parts are probably bad. I would also make sure that the headlight bulbs are good. Do the brights work?
Old Feb 12, 2013 | 02:43 PM
Car: 84 Camaro
the dims and the brights dont work. I was thinking I should replace the headlight switch, but I wanted to get your guys opinion.
Ghettobird52
Jul 5, 2024 11:18 PM
GTAman
Mar 15, 2019 11:40 AM
DiabolicalRS
Aug 26, 2015 07:35 AM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
