Have spark, FP primes, no pulse, code 12, 46 possible VATS issue?
Old Feb 20, 2013 | 08:15 AM
TheSumOfOne's Avatar
How do i start diagnosing the vats system?
Old Feb 20, 2013 | 08:37 AM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
Re: Have spark, FP primes, no pulse, code 12, 46 possible VATS issue?
i don't think you would have spark if it's the vats causing it .
Old Feb 21, 2013 | 12:19 AM
Ok well just to be sure I replaced the Complete Distributer and coil as the coil pickup was not plusing the injectors. Now I'm thinkin its a vats.... Vats system seems to be working, Security light turning off after a few secs.. After reseting my ecu code 12 is the lone code...
Old Feb 21, 2013 | 06:37 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by TheSumOfOne
Have spark, FP primes, the coil pickup was not plusing the injectors. Now I'm thinkin its a vats.... .
VATS only disables the fuel injectors ( and starter ). Even if the ECM is seeing the dist ref pulses from the pickup you will get no injector pulse when VATS is active
Has nothing to do with pump or spark
If it is cranking over ( unless your starter relay operated by VATS has been bypassed ? ), then it is possible but unlikely to be a VATS problem .
have you checked the injector fuses?
Read
https://www.thirdgen.org/vats_passkey_system
Old Feb 21, 2013 | 11:31 AM
Read
Fuses good.
Glowsock
Jul 24, 2025 03:15 PM
Street Lethal
Apr 30, 2019 12:14 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
djmarch
Aug 9, 2015 05:27 PM
