running 12v to msd distributor
Old Feb 23, 2013 | 01:29 AM
Slow87's Avatar
Car: 87 Camaro Lt
Axle/Gears: 4th gen 3:42, posi, disc
I just bought a streetfire dizzy. There is a connection labeled Batt. The instructions say I need to run 12V through at least a 14 gauge wire. Where would be the best place to pull power from? The white/pink wires from the old coil are 20gauge (so I read), so that option is out.
Old Feb 23, 2013 | 05:48 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: running 12v to msd distributor
Originally Posted by Slow87
Where would be the best place to pull power from? The white/pink wires from the old coil are 20gauge so that option is out.
Would have to replace the pink wire all the way back to the Ign switch as that is where the supply comes from for the coil
Old Feb 23, 2013 | 10:18 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The factory wires aren't even close 20 gauge. Where did you read that?
Old Feb 23, 2013 | 04:54 PM
Slow87's Avatar
Car: 87 Camaro Lt
I read it in another forum. What connection do I use? There are two connections that clip into the stock coil. Both of them have white and pink wires.
Old Feb 23, 2013 | 07:14 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Simple
One of the plugs on a dual connector coil goes to the harness (Ign switch ), the other to the dist.
Use the pink wire from the plug that goes to the harness
If you want your tacho to work use the white from that same plug to the new dist
89GTAOz
May 16, 2020 09:31 AM
9192camaro
16
Feb 3, 2019 12:21 AM
Jae992
Aug 27, 2015 09:07 AM
midias
Aug 15, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
