marker lights intermittently shut off
Old Feb 23, 2013 | 06:36 PM
steviemac01's Avatar
I have seem to notice that the marker lights intermittently shut off for a few minutes then come back on. does anyone else have this problem?
Old Feb 23, 2013 | 09:32 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: marker lights intermittently shut off
When my Firebirds have done this I usually re-seat the bulb and that takes care of it.
Old Feb 23, 2013 | 10:48 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Is the full SET of marker lights doing this in unison, or is it just happening one light at a time?
Old Feb 23, 2013 | 11:21 PM
yes the whole circuit. (marker lights, instrument lighting and dinger) tried looking for a fuse but couldn't find one
Old Feb 24, 2013 | 08:02 AM
W.E.G.'s Avatar
Engine: V6 2.8
Spontaneous on-off-on-off behavior is not consistent with a fuse failure.
If a fuse goes, its gone until you replace it. Blown fuses don't just come back on.
On-off-on-off behavior impresses me as most likely a bad ground connection.
Trace the marker lights' circuit back to the relay that serves these lights.
A relay can play the on-off-on-off game on you, especially if the ground for the relay is decayed.
Inspect entire circuit for damage/deterioration.
A wiring diagram for your car will be helpful.
Rakim_RS25TH
Aug 27, 2015 05:04 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Omega
Aug 10, 2015 12:46 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
