Rear turn signals not working
Hey all, I 1990 Camaro convertible and the rear turn signals are not working. the front and sides are functioning fine. I checked the bulbs and the were good. I check for juice and there is no juice coming to the sockets. I also check the wires and no juice there either. I figured it couldn't be the flasher because it working fine up front. Any Ideas?
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Rear turn signals not working
There is no relay.
You can check the rear harness connector (if you can find it, it's pretty hidden on my convertible). It should be accessible behind the left sail panel (with the left rear speaker).
Or you can just probe the dark green and yellow wires under the carpet next to the driver door sill. If no power there, we will need to move up to the steering column.
Let us know what you find.
Lou
Lou
Engine: TPI
Then you can probe just the dark green wire, that's for the right turn signal. Make sure it's the DARK green wire because there is also a light green wire in the loom (for reverse lights).
db057
Aug 11, 2015 10:11 PM
