Need help with alt wiring/'84 Firebird
Old Feb 28, 2013 | 11:45 AM
Zoro's Avatar
Got an '84 Firebird that was originally an A/C car w/rear defrost and rear wiper. The car has had about 4 or 5 different motors in it in the last few years and some things got changed along the way. Right now the car has a driver side dipstick 350 with the old style brackets and an alternator for a non AC car. Also got rid of the computer controlled carb and all the smog stuff.
Here's the problem. Somewhere along the way somebody hacked and got rid of the alternator wiring harness, it's gone. How can I hook the alternator up so it's doing what it needs to be doing?
Old Mar 5, 2013 | 06:05 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Wire Mire
The heavier red wire goes from a Fusible Link, to the positive stud, and should have power at all times.
The
thinner red wire goes from a different Fusible Link, to terminal S (the sensing circuit) and should have power at all times.
The
brown wire goes to terminal F (the turn-on input) from the FAN fuse, and should have power when the key is in the RUN position.
Happy Racing!
Make Noise, Turn Left, Repeat
Old Mar 5, 2013 | 06:12 PM
Zoro's Avatar
Re: Need help with alt wiring/'84 Firebird
Thanks!
jtwoods4
Sep 3, 2015 05:39 PM
Formula_88AE
Sep 3, 2015 01:47 PM
jtwoods4
Sep 3, 2015 10:19 AM
Slush92RS
Sep 2, 2015 08:56 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
