Headlight problem
Old Mar 1, 2013 | 12:12 AM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
Headlight problem
My firebirds headlights raise... sometiimes, the lights always turn on even if they dont raise so it cant be the switch but it is embarressing to have to get out and have to raise the hood and manually lift the headlights when they decide to act up. Is it the module?
Old Mar 2, 2013 | 02:11 AM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
Re: Headlight problem
Really no one has an idea?
Old Mar 2, 2013 | 07:18 PM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
Do people dont understand what is going on as i need to write it out better or just no ideas?
Old Mar 4, 2013 | 10:25 PM
locutus918's Avatar
Car: 89 formula firebird
Engine: formula 305 TPI
Transmission: 5 speed
Axle/Gears: 3.45
could be what i did with mine was bypassed module and installed some toggle switched to raise and lower on my 89 formula all it does is reverse polarity to raise and lower you might disconect it hook up to battery and reverse to test motors on mine the module that controls motors was about 200 so i bought 2 toggles and wired in to reverse polarity much cheaper lol
Old Mar 4, 2013 | 11:07 PM
88formula305tpi's Avatar
Car: 1988 Firebird Formula WS6
Engine: 305 tpi lb9
Axle/Gears: 3.45
alot of headlight problems I just posted a link on another thread and described what I had to fix the 2 times mine wouldnt work. Both times they wouldnt work intermittently. if you hear the motors making noise and they go up sporadically its most likely the ***** are grinded up inside the gear housing. I rebuilt mine with a kit from topdownsolutions. not sure if the kit is still available or not but it had new ***** gaskets etc. they worked like new for a couple more years then had to bang on the dash pop the hood or slam a door to get them to pop up. ended up doing like in this video to fix the loose solder connections inside the module itself.
https://www.thirdgen.org/forums/elec...air-video.html
Old Mar 4, 2013 | 11:29 PM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
no mine doesnt make any motor sound. Its like the motor is not getting power nut the head lights still turn on.
Old Mar 5, 2013 | 06:18 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
More Doors Chores
Using a voltmeter or test light (the type for testing for voltage, not a continuity tester) to probe the headlight module terminal 1A yellow wire, then 1C brown wire, to see if they get power when you turn the headlights on.
The headlight module is a rectangular unit about 3" x 4" mounted in a bracket on the left side of the firewall.
It has two connectors.
The prong that sends power to the lamps is the same one that sends power to the door module.
Because they open sometimes there is an intermittent connection which you need to find.
Wire up a small 12 volt bulb
(a side marker bulb works best).
Connect one lead to ground and the other lead to pin 1A
yellow wire on the module.
Make the wires long enuff to bring it into the cockpit.
The next time the doors don’t open observe if the bulb is illuminated.
If it is, you will know that control power is getting to the module therefore test or replace the module.
If the test bulb is not illuminated, you will know that control power is not getting to the module there you merely have to restore that one connection.
Happy Racing!
Make Noise, Turn Left, Repeat
Ghettobird52
Jul 5, 2024 11:18 PM
GTAman
Mar 15, 2019 11:40 AM
DiabolicalRS
Aug 26, 2015 07:35 AM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
