need help identifying connecters
Car: 89 formula firebird
Engine: formula 305 TPI
Transmission: 5 speed
Axle/Gears: 3.45
well on way home tonight im guessing a ground cable behind coil broke and rubbed thru some wires actually lighting them on fire the pic is kind crappy its when i first got the car i blew up area in question i can get a better pic if it helps this is an win f 89 formula firebird i need to know if anyone knows what these connectors are for at the same time this happened i got a massive draw on battery to the point nothing works even the check engine light is so dim you cant tell its on when trying to start when this happened i shut off car put the flames out and tried to restart car to get home and no luck no response from starter or anything other then fuses and fusible links which i havent checked yet any ideas on this issue as well? Thread Starter
Axle/Gears: 3.45
Re: need help identifying connecters
still no idea what the go to 2 of them look almost like fusible links the other has i think 4 cables on 1 side two on the other but got car running again some how a main battery cable got nicked about the same time and welded itself to body without burning up so that was power draw still would love to know the larger connector so i can replace it
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
the one in the yellow box looks like the tach wire
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
What color wire is in that single connector in question? If Tan/Black, it is your Set Timing connector C146.
