Battery drain
Car: 1991 Z28 Camaro
Engine: 5.0
Battery drain
I installed a new cooling fan switch (on at 200 off at 185) the thermostat is in conflict at 195, so the fan is always on. I can charge the battery overnight and after about 2 weeks of driving it will barely crank. Would this fan always being on cause enough of a draw to not charge the battery?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Battery drain
do a paramedic draw test and check out your battery and charging system.
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: Battery drain
Sorry mate - born Aussie - smarta$$ comes built-in
Jhook - Tuned means no, the fan should not be able to run the batt down even if it's on all the time the engine is running. There is a deficiency in the charging system, or some kind of draw on the power while the car is not running that slowly flattens it over a couple wks.
raymondandretti
Sep 27, 2015 06:43 PM
