Starting issues
Old Mar 9, 2013 | 01:31 PM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
Starting issues
Hey guys long story short I replaced my dash harness an now car won't crank. Where should I start to look for. When I turn the key the fuel pump starts but I am running an xfi unit.car just won't crank. Is there something I should be looking for in the harness itself. My car is a five speed (well t56) if the harness I put in is from an automatic tranny is there something I need to jump out. Also how can I tell if I have a bad ignition switch. Car is a 86 camaro and the replacement harness came out of an 86 also. I matched up all o the connectors on the bulk head and they were the ame as my old harness
Old Mar 9, 2013 | 02:43 PM
smokefan's Avatar
Re: Starting issues
ok i got it figured out. no worries
Old Mar 9, 2013 | 03:20 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Starting issues
That was fast!! Good job!!
So what was the problem?
Old Mar 10, 2013 | 07:35 AM
smokefan's Avatar
Re: Starting issues
Harness must of been from an auto tranny. Had to jumper the switch to the starter
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86Base
Aug 8, 2015 01:34 PM
