2.8L swap to 355 carb engine
Old Mar 13, 2013 | 09:46 AM
90camaro355rs's Avatar
Car: 72 nova/ 90 camaro rs,04 suburban
Engine: blown 327/ 355/306/355/5.3
Transmission: muncie 4 speed/T5/powerglide,4l80e
Axle/Gears: 342/411/456/ moser axles
I have a 90 camaro rs that had a 3.1 v6, engine and trans was not in the car when I got it, none of the wiring either, I put the wiring harness in the dash and the engine compartment, I am not new to cars at all, I am stumped on this though. Everything in the cluster works except the fuel guage, does the ecu/ecm need to be plugged up in order for the fuelguage to work? Wires are connected at the fuel sending unit and connector under the carpet inthe back. I have checked all fueses in fuse box. Does the grey wire going to the ecm need to have power? Anyhelp would be awesome, I thank you ahead of time! Tim
84z96L31vortec
Aug 20, 2017 12:16 AM
theshackle
Mar 5, 2017 06:37 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
