Security light comes on but car runs fine?
Old Mar 23, 2013 | 07:20 AM
usc iroc's Avatar
Car: 89 Iroc
Engine: 383
Transmission: 700
Axle/Gears: 4.11
I have noticed 1/2 the time my security light will come on and stay on but car runs fine? Maybe a false signal? Should I just ignore it till I redo the gauges?
Old Apr 1, 2013 | 04:35 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Key Largo
The 18 AWG gray wire coming out of the dash connector might be shorting to ground.
Physically inspect it.
If the wiring is OK the problem is in the Pass Decoder Module.
With the car OFF, unplug the 2 pin connector near the steering column which contains a
White wire with a black stripe, and a purple wire with a White stripe.
Then, turn the key to RUN and measure the voltage between the
White wire with a black stripe and ground.
There is supposed to be 5 volts there.
If there is, measure the voltage between the two wires on the 2 pin connector pigtail.
There is supposed to be 5 volts there also.
Was there approximately 5 volts on both those locations?
Happy Racing!
He Must Have Been Be Cheating - Because I Was And He Almost Beat Me.
theshackle
Mar 5, 2017 06:37 PM
Wade787b
Sep 29, 2015 01:15 PM
Omega
Aug 10, 2015 12:46 PM
Kaweh
Aug 9, 2015 02:54 PM
Sherpajames
Aug 7, 2015 06:56 PM
