1986 iroc z 305 fi PLZ HELP CAR WONT START!
Old Apr 3, 2013 | 01:54 AM
camaro86iroc's Avatar
ok so I had to replace head gaskets in my 86 iroc z tuneport motor. it ran before now I got it back together except for the distributor cap and now my fuel pump wont kick on, turnover, and I get no dash warning lights. any ideas? I also replaced the heater core meaning I took out the computer could it be fried?
Old Apr 8, 2013 | 01:06 AM
Lucid's Avatar
Car: 86 Camaro Z28/ 87 Camaro IROC Z28
Engine: 5.0L TPI LB9 / 5.0 TPI LB9 w/cam
Transmission: Built 700R4 with Transgo shift kit
Axle/Gears: 3.27 9 bolt Posi/ 2.73 10 bolt Posi
Re: 1986 iroc z 305 fi PLZ HELP CAR WONT START!
Can you explain the problem a little better? Its hard to understand what problem you are having because you need to elaborate. Also, what have you tried to do to troubleshoot the problem?
Check your fusible links going to the starter because they provide power to the dash.
Old Apr 8, 2013 | 04:16 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Primetime
With the car off, jump battery + to pin E gray wire
of the pump relay (or the under-hood test connector) and listen for pump whine.
Did the pump run when you did that?
Happy Racing!
After The Fourth Barrel Roll I Lost Control Of The Car
Old Apr 10, 2013 | 03:00 PM
beths91camaro's Avatar
Car: 87 Iroc vert, t-top
Fusible links would be where I would start. Check the one over by the battery- that was the one that was the culprit on my buddy's 86.
Steven 86IROC-Z
May 24, 2026 04:52 AM
Wade787b
Sep 29, 2015 01:15 PM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
