Horn switch Slip Ring Plastic Wiring Connector
Old Apr 3, 2013 | 02:50 PM
91RSCamaroSteve's Avatar
Car: 91 Camaro RS
Engine: LSX 5.3 226/228 596/598 113
Axle/Gears: 3.42 Posi
So after trying to diagnose the malfunctioning horn I finally made it work but I realized that the plastic piece inside the steering wheel that connects the red wires from the switch to the slip ring is broken and I can't put the red wires back in.
I was wondering if it was possible to buy it and if so what do I need to get for that or ask for?
I will post pictures in a minute as I am using my phone right now.
Old Apr 4, 2013 | 12:26 PM
Car: 91 Camaro RS
Re: Horn switch Slip Ring Plastic Wiring Connector
Disregard my last, I ended up "building" a new switch and the plastic connector that pushes the spring on to the slip ring and horn works better then it has since I got it.
Just glad to get the safety done so I can swap out the 305 TBI for the 5.3.
Thanks for anyone that had a look at the post but I guess too many coffees and being stubborn means you will find a way to make it work.
Old Apr 12, 2013 | 08:50 PM
Marius's Avatar
Car: 1990 RS Vert
Engine: 305 TBI
Transmission: 5spd
Axle/Gears: Stock
How did you end up fixing the problem? I have the same issues with my 1990 RS.
Old Apr 17, 2013 | 03:36 PM
Car: 91 Camaro RS
Sorry man I have been busy trying to finish my LSX swap but I'll post some pictures and an explanation of what I had to do tonight.
Sorry for delayed response.
Steve
eightsixseven
Dec 16, 2024 01:50 PM
89GTAOz
May 16, 2020 09:31 AM
Infested
May 22, 2018 11:56 PM
Caspar
Jun 19, 2016 11:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
