distributor power wire
Old Apr 4, 2013 | 07:21 PM
camaro86iroc's Avatar
Ok so I have an 86 iroc z with the tuneport injection, I'm getting fuel but no spark. I checked the voltage at the distributor cap and had no voltage I believe the power wire went missing does anyone know which wire is the power? Or if there may be any other cause to the problem I'm having?
Old Apr 4, 2013 | 07:36 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: distributor power wire
On a HEI dist ,the pink wire to the terminal marked BATT on the dist cap should have 12V with the key on.
The white wire on the TACH terminal is for obviously the tacho signal
Old Apr 5, 2013 | 03:02 AM
Ok but when I looked my tachometer wire was orange and brown does that make a difference?(atleast thats what the guy said whi was helping me) And does the four pin connector have anything to do with powering the distributor?
Old Apr 5, 2013 | 09:10 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
On a car that old anybody could have done anything...........
All you need is 12V on the wire to the terminal marked BATT when the key is on
Those are the wires to the computer (the ECM ) that control the spark
Old Apr 6, 2013 | 07:49 PM
Ok so I have power to it now but still no ignition I have fuel but it won't fire. Any more ideas?
Old Apr 6, 2013 | 10:58 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Auto Spark Basics 101
http://easyautodiagnostics.com/gm_ic...n_module_1.php
Time to find out where your spark problem is
Old Apr 10, 2013 | 09:02 PM
Ok so I git it all hooked up and it starts and runs thanks. But now it will stall at like a red light it will start back up but when I'm in low rpms it'll kill. I'm thinking fuel pump or timing is off a little. I don't have a timing tab on the car I bought an aftermarket one but have no idea how to install it. Its a spectre timing tab. Any ideas on how to install it or how to time it better by ear?
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Caspar
Jun 19, 2016 11:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
