new battery cables. where to start??
Old Apr 8, 2013 | 09:09 PM
Mailman818's Avatar
Car: 89 firebird bone stock for now
Engine: 2.8L V6
Axle/Gears: B.W 9Bolt 3.27 Posi
im looking to get new battery cables for my car. i have power thats never consistent and i think the power transfer isnt enough as sometime my car turns off from going to drive from reverse. looking at where to start and what other people recommend? which cables should i also swap besides the main battery cables? what gauge sizes should i go with and how much would i be looking to spend? thanks guys -Aaron
Old May 3, 2013 | 12:22 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Reverse Voltage, A Big Negative
A set of battery cables will be about $20.
Typical gage is 2 AWG.
If it’s stalling when shifting into reverse do to a voltage drop, that can be verified by using a voltmeter with leads long enuff to reach the cockpit.
Connect it to one of the headlights, turn the headlights on, you should see about 12 volts.
Now start the car, put it in reverse, and observe the voltage when it stalls.
Did the voltage drop and by how much?
Happy Racing!
My Brakes Don’t Work AT ALL When The Car Is In The Air
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
justin57
Aug 20, 2015 07:05 PM
