Wiring a manual fan switch?
Old Apr 10, 2013 | 08:18 PM
MeenZ28's Avatar
Car: 1992 Z28 Targa Top. Full air ride
Engine: 305 5.0 tpi v8
Transmission: A4
Axle/Gears: 3.73 gears posi
I need a simple step by step on how to wire the cooling fans to a switch. Although my fans work fine on thier own, Summer is comming and i'd like to have that extra piece of mind. Any help would be appreciated.
Its a 305 tpi a4 with dual fans bone stock if it helps
Old Apr 11, 2013 | 05:29 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Wiring a manual fan switch?
Run a wire from the control side of the fan relay ( the dk grn / wht wire , bottom RH corner in diagram ) to ground through a switch
If you want both fans to work off the switch , then wire the control side of both relays together
Not for your year but you get the idea
Old Apr 11, 2013 | 06:47 PM
MeenZ28's Avatar
Transmission: A4
Maybe a dumb question but, the fan relays, where in the engine bay are they? Im pretty sure i know one is on the firewall on the driver side by the brake booster... Is the other one there too or somewhere else?
Old Apr 11, 2013 | 10:38 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
There is a button at the top of the page
Old Apr 12, 2013 | 03:18 PM
MeenZ28's Avatar
Transmission: A4
Your link didn't work but I'm familiar enough with the search function. Found what I needed. Thank you for all your help my friend.
Old Apr 13, 2013 | 12:10 PM
MeenZ28's Avatar
Transmission: A4
Sorry..... Blonde moment.
Old Apr 14, 2013 | 09:00 PM
rwriley563's Avatar
Car: 89 rs
Engine: 305 tbi
Transmission: autotradgic
I traced the wire that comes off of the temp sensor for the fan then I spliced on a wire to that ran it to the firewall to a switch and ran that switch to ground. Grounding that wire will energize the relays and presto fans on command
Old Apr 15, 2013 | 12:22 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by rwriley563
I spliced on a wire .................... to ground. Grounding that wire will energize the relays and presto fans on command
Kinda , exactly like I said in post #2 above
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
89GTAOz
May 16, 2020 09:31 AM
Caspar
Jun 19, 2016 11:19 PM
TA8487
Aug 16, 2015 12:21 PM
