cant get codes
Old Apr 13, 2013 | 06:44 AM
alpinestars199's Avatar
Car: 89 firebird formula
Engine: 305 5.0
cant get codes
I have a check engine light on in my 89 formula and I'm trying to get the codes to flash by jumping pins a and b on the dlc connector but all that happens is the fans start spinning. Or at least that's what it sounds like. Any ideas ?
Old Apr 13, 2013 | 10:19 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: cant get codes
A quick search can help.
https://www.thirdgen.org/service-eng...ht-error-codes
Old Apr 13, 2013 | 10:28 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: cant get codes
The lack of communicatin kinda points towards a bad ecm, pin a8 on the ecm or pin E of the aldl with the key on should be over 2v but most of the time it will be close to 5v. Another cause for the light to be on is the brown/white wire from the mil being grounded. You can try reseating the memcal as well to see if the mil goes off.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
