Wiring aftermarket switches
Old Apr 13, 2013 | 09:09 PM
Soehnm's Avatar
Car: 1990 camaro rs
Engine: Small block chevy 350
How's it going. I picked up a 90' rs a couple months ago. The guy that had it before me has a switch panel above the radio. The switches are for the water pump, fan, fuel pump, and the radio.. The only problem is the wires go straight to the battery with no fuses between. I'm not to good on wiring but I know they need a fuse somewhere to prevent the car catching on fire. I wanna clean up the battery and not have so many wires going to it as well. Any suggestions on what to do? Thanks...
Old Apr 13, 2013 | 09:33 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: Wiring aftermarket switches
Maybe buy a small fuse block and mount it under the hood somewhere. Here is one example; http://www.ebay.com/itm/ATC-ATO-4-way-Raised-Fuse-Block-/350758700574?pt=Motors_Car_Truck_Parts_Accessories&hash=item51aad9061e&vxp=mtr
Old Apr 13, 2013 | 09:42 PM
Soehnm's Avatar
Car: 1990 camaro rs
I was looking into that. Now with that do I still have to run each to the battery? Or can I just run positive and one ground to the box and then go out from the box to the switches and out to what I'm running? I just don't want like 5 positive wires on the battery... Thanks..
Old Apr 13, 2013 | 09:54 PM
red rock's Avatar
Car: 1987 iroc
Did you not watch the little video? There is a variety of ways to hook up blocks. I just gave you one example.
Old Apr 13, 2013 | 10:05 PM
Soehnm's Avatar
Car: 1990 camaro rs
Sorry I didn't catch the video. I did this time. Found out what I exactly need. Thanks for the help...
Old Apr 13, 2013 | 10:12 PM
red rock's Avatar
Car: 1987 iroc
Old Apr 14, 2013 | 12:26 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by Soehnm
The switches are for the water pump, fan, fuel pump,.
Hopefully it has been wired up properly and the switches operate the relevant relays
and don't just take power straight from the battery to the item?
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
Street Lethal
Apr 30, 2019 12:14 PM
355sbcTPI
Aug 19, 2015 04:38 PM
ZsTransAm
Aug 11, 2015 07:30 PM
